    ROMNI - My 3D Printed New tiny RecalboxArcade :)
    Your recalbox
    romni printed tiny recalboxarcade
    9
    20
    7661
    • Marcelo Souza
      Marcelo Souza last edited by acris
      ![alt text](0_1493615945927_Romni_03.jpg image url)
      I would like to present my new project. My 3D Printed tiny recalbox Arcade. with sanwa control, 3.5 screen (composite), sound, batteries, etc. Hope you guys like it ! 🙂
      (The shaft will be replaced by a shorter one soon). 🙂
      I can´t wait for Recalbox 4.1 so the project will be "more" complete. 🙂 And i have a question...Is it possible to have composite video working and auto-change to HDMI output when using the hdmi output ? My Romni arcade has a hdmi extension on the back, but when i plug it, the hdmi only show the first colored box on Pi boot then it goes to the composite... I followed the tutorials to have composite output, and maybe they FORCE the composite output... But i would like to be able to use the internal screen and the external monitor (hdmi). NOT at the same time of course...
      Is that possible ?!
       This is my first post on this forum. Glad to be here. :) Thanks !
      Marcelo Souza 1 Reply Last reply Reply Quote 3
      • Marcelo Souza
        Marcelo Souza @Marcelo Souza last edited by
        @Marcelo-Souza 0_1493616465672_17662135_298345533928565_651634508323356672_n.jpg 0_1493616498559_C9Ag99OXYAAEDN7.jpg 0_1493616527763_17882849_1833365770257069_2210567466218684416_n.jpg
          Hello
          good projet 😄 , screen too small for me,
          recalbox 4.1 https://archive.recalbox.com/updates/v1.0/unstable/
          Marcelo Souza 1 Reply Last reply Reply Quote 0
            voljega Banned @Marcelo Souza last edited by
            @Marcelo-Souza I love it, really beautifull !
            But maybe a short handle for the joystick would be better ? It seems to stick out a little too much compare to the size of the bartop
            • ian57
              ian57 Staff last edited by
              I love it. Great job
              • Marcelo Souza
                Marcelo Souza @voljega last edited by
                @voljega said in ROMNI - My 3D Printed New tiny RecalboxArcade 🙂:
                Yes. Certainly ! 🙂
                I ´ve mentioned that the shaft will be replaced by a shorter one. This one was used just because it´s the only one i had at the time i´ve built it. 🙂 It´s 7cm long, but i don´t have all this space inside the case, so, i rebuild all the internal parts of the original sanwa with 3D Print, to reduce the size, and leverage the shaft by 1cm (this red ring on it´s base)... Using a shorter shaft, like 6cm i will be able to remove that red ring, so the shaft will be lower. 🙂
                But anyway, it´s working perfectly and not getting in the way of the screen. So it works for now. 🙂
                • Marcelo Souza
                  Marcelo Souza @ian57 last edited by
                  @ian57
                  @ian57 said in ROMNI - My 3D Printed New tiny RecalboxArcade 🙂:
                  Thks Ian ! 🙂 I love it too. Lol. Playing it everyday ! 🙂
                  • Marcelo Souza
                    Marcelo Souza @acris last edited by Marcelo Souza
                    @acris said in ROMNI - My 3D Printed New tiny RecalboxArcade 🙂:
                    Hello
                    Thx Acris !
                    I am waiting for the stable one. But but maybe i will test the unstable for curiosity sake. lol.
                    I agree that  the screen is not for everyone. But it´s a design/cost option. It´s very hard to find bigger screens, not SO big to have to change the entire design/power scheme, that has composite input and it´s cheap. That screen i am using is around $25... And i live in Brazil, so it´s not easy to get anything i want to + the import taxes can be like 100% the price + shipping... So, the decition has a lot of constraints. But it´s a nice screen for it´s price, and it´s bigger than my dingoo a320 screen. If i am able to find a good Cost Vs enefit on a 5 inch screen that would be perfect. And as it´s a 3D printed case designed by me it´s just a matter of modifying the 3D model and printing the top part again.
                     BTW...Any clue about my Composite/HDMI question ? Is it possible to auto-switch to hdmi output when a HDMI cable is present ? (Even if i need to reboot it) ?
                     BTW 2 : I don´t know why my posts here are being showed on a black box... :(
                    • Marcelo Souza
                      More Pics ! 🙂 BTW this project is not 100% finished on it´s design. It´s the Prototype #6 (6 case printed until now). So there´s some minor updates/differences between some pics. 🙂
                      This is the prototype #6 :
                      alt text
                      Some shots of the new Back with removable plate, so, i can use any different board, and have a more futureproof design. I just need to reprint the red plate to fit a new configuration for the board ports. 🙂
                      alt text
                      A shot of the front control pannel. With Power ON/Off button, Hotkey, Select and Start buttons. 🙂
                      alt text
                        Hello @Marcelo-Souza
                        I have the same problem to buy products.
                        for your question hdmi :
                        try these :
                        mount -o remount,rw /boot
                        edit this filenano /boot/config.txt
                        add this line : hdmi_force_hotplug=1
                        when you start without hdmi cable, normally it's ok
                        et when you plug hdmi cable, normally it's boot to TV screen
                        • Marcelo Souza
                          Thanks for the Tip. I will try it now ! 🙂
                          try these :
                            Hi ! Nice game&watch arcade cab ^^
                            For your question regarding composite/hdmi auto select ... Hard to tell, i'm not sure anyobe ever succeeded here
                            • Marcelo Souza
                              Marcelo Souza @Substring last edited by
                              I am back to this posts. Just to post a possible "solution" for my obvious question... A way to Auto-Switch between HDMI<>AV... It seems that this guy made a script that Detects the hdmi plug and switch the config settings...
                              Hope it works ...
                              https://github.com/superjamie/lazyweb/wiki/Raspberry-Pi-Display-Auto-Switching
                              @acris Hey.
                              I´ve changed the lines with hdmi_Force_hotplug=1 and then it worked, the recabox and games apearead over hdmi (video and audio) but now , even after unplugin the hdmi and turning off and on the system again, it´s sticked with hdmi output... The monitor i am using only turns on if some signal enters over the composite in... so it seems that pi isn´t sending composite signal anymore after i unplugged the hdmi cable. I will reverse the config edition to check...
                              • azvarel
                                azvarel last edited by
                                A W E S O M E
                                I love it all very much
                                Zodian Theme | #SNESProject
                                • Marcelo Souza
                                  Finally reach the beta stage with my project. 🙂 Hope you guys like it.
                                  Now i need to build a custom theme, since the latest recalbox has "SMALL SCREEN" themes, but the gamelist font stills VERY tiny... Unreadable. 😞
                                  0_1529165529787_Romni_2018_Top_01_make.jpg image url)
                                  voljega 1 Reply Last reply Reply Quote 4
                                  • Dragu
                                    Dragu Banned last edited by
                                    @Marcelo-Souza
                                    You can edit the themes and increase the font size very easy.
                                    By the way, I also find it very nice, and having some 4.1" compo spare screens, I think about it.
                                    • protoplasta
                                      protoplasta last edited by
                                      It looks just amazing.
                                      https://mmoauctions.com/eve-online
                                      • Gaetan
                                        Gaetan Theme moderator last edited by
                                        Much better than the neogeo mini !
                                        And you can have all the neogeo games collection in it 😉
                                          @marcelo-souza beautiful !
                                          how are the buttons ? I've always wondered of those kind of mini buttons were and felt as good as the standard ones
                                          • ian57
                                            ian57 Staff @voljega last edited by
                                            @voljega if it is small "service buttons"... they are very hard; and it is difficult to play with.
                                            100.3k
